Need a lift pump or injection pump for 400D.
Nick Friend
06-25-2006 09:05:59
I replaced my filters but still not enough pressure to keep running at high rpm. Any and all help would be great.
Geoff NY
06-25-2006 15:00:59
 Re: Need a lift pump or injection pump for 400D. in reply to Nick Friend, 06-25-2006 09:05:59
You should check for leaks first. When I first started with this hobby I bought a lot of parts I didn"t need. Air leaks are a problem. Also make sure the pressure gauge is good. I would dissasemble the plumbing and check the tank to make sure the fuel lines are clear. One of mine had a check valve in the return line that stuck and gave me low pressure. If all the lines are clean (good flow) and there are no leaks then look into some new parts. Have fun, Geoff
