What yr is date code P
MJF
06-25-2006 11:27:27
I have a little problem with my one M. It has had a different flywheel housing put on it, so the serial plate is wrong. So can anyone tell me what year it would be with the casting date code P. Thanks for everything
Milton
06-26-2006 08:50:35
 Re: What yr is date code P in reply to MJF, 06-25-2006 11:27:27
MJF, --- 26 / June / 2006 ---
The "J" would be a 1946. If you would check for
the original paint on your "M" tractor, it may show up as being "PINK" .
Regards, Milton
MJF
06-25-2006 12:02:14
Thanks thats what I needed
It goes like this.
06-25-2006 11:54:12
1931 is A, 1932 is B, and go on in consectitive order until 1951 U and W were used in 1951 and V was skipped, 1952 is X, 1953 is Y. and 1955 started over with A. Pis 1946.
