plow manual needed
Daniel H.
06-25-2006 12:15:58
I have a two-way plow for a one-point fast hitch that I have been looking for a manual for over a year. I've tried all the usual sources such as Binder Books and several vendors at Red Power Round-Up last year. I even contacted the IH archives and Case/New Holland. No one has one. I am hoping somebody has one tucked away in a drawer some where that I can get a copy of. The plow is a 1-F11 for the Super A/100/130/140 with fast-hitch. In 1959 it became the 101 two-way moldboard plow. It has both a left and right bottom. The manual part number CNH gave me is 1005932R1. Thanks for any leads.
Daniel H.
06-27-2006 12:38:45
 Re: plow manual needed in reply to Daniel H., 06-25-2006 12:15:58
The reason I was looking for the manual was to get the settings for the hitch on the tractor. I have a copy of the cub version of the plow manual, so I think I have it close, but I am still not quite satisfied with it. I was hoping the manual would help. Thanks.
evielboweviel
06-25-2006 17:25:23
look here can't link it use www. then copy the rest
cleancomputes.com/Cub/Cub%20Implement%20Manuals/Cub-F%2011%20Two-Way%20Moldboard%20Plow/Cub-F%2011%20Two-Way%20Moldboard%20Plow.htm
good luck
Ron
Bob Bedlan
06-25-2006 13:38:41
I can't help you with a manual,but have the IHC
parts catalog for moldboard plows. It shows the plow that you have. F11 was built 1955-58. 101 was built
1958-1967.
Hugh MacKay
06-25-2006 13:37:40
Daniel: I can't help you with a manual, but I do have a dealer parts book that contains a 5 page section on your plow. If you wish to e mail me we can make arrangments to send you copies of those pages.
I can't understand Binder not being able to provide you with a manual, especially when you had the model number. That plow was not a high volume production plow, thus they must not think it worth their while to reproduce the manual.
Did you think to ask them about the same type plow, only 2 point for Super C, 200 and 230. The only thing different on that plow from yours is the hitching. The actual plow and the pivot are the same.
