Starter service plastic plates
ToddH
06-25-2006 12:49:26
Hi, I was servicing my 1953 super c starter and when I took off the switch housing that is mounted to the top of the starter, two plastic plates fell out. I assume these are insulators between the switch housing and the starter but I"m confused because the two screws that mount it to the starter would keep it from being insulated even with these plates inplace. The two black plastic plates are about a 1/16" thick and are some what triangular in shape and do not have any holes or notches in them. I reassembled without them and the tractor turned over fine but when I realized that I left them out, I thought I should find out what they are needed for. Any help is much appreciated, Todd
Marty Johns
06-26-2006 18:45:36
 Re: Starter service plastic plates in reply to ToddH, 06-25-2006 12:49:26
Must have been a later addition! I have a mid forty's A and have replaced the switch twice and neither have had the incerts!
Brownie 45
06-25-2006 16:58:38
Just install one on each side, vertically, inside the switch.
Farmalldan
06-25-2006 14:30:02
Todd,
Those are the insulators between the sides of the switch housing and the contactor. You may experience shorts to ground inside the switch housing without them.
