H, replacing rear end, simple though heavy right?
arod
06-26-2006 12:56:38
Have determined my transmission is garbage, upon removing the top cover, the gears faces are extremely rusty and pitted, and there are too many pieces of broken roller bearings scattered through the case, leaky axle seals too. so I decided to say hell with fixing all those problems and to purchase another rearend.
should be simple but heavy, I'll get a cherry picker, to swap rear ends right? I have the tractor stripped, just have the drive shaft left to uncouple, then the last step is unbolting the torque tube from the tranny and do the switch, right?
MJF
06-26-2006 17:51:58
 Re: H, replacing rear end, simple though heavy rig in reply to arod, 06-26-2006 12:56:38
We've did it with an H and an M. Changing rears is much easier than digging bearings out. Good luck and have fun
MJF
06-26-2006 13:02:35
If you have another tractor just back them drawbar to drawbar and bolt them togather. Unbolt the old rear and drive away
arod
06-26-2006 17:20:16
 Re: H, replacing rear end, simple though heavy rig in reply to MJF, 06-26-2006 13:02:35
that is a fantastic way of handling the job, thanks for the tip
