water pump leak farmall H
Eddie123
06-26-2006 14:18:43
I have a leak running down the fan blades on a farmall H and it continues to get worse. I assume its the water pump or a seal. I have the radiator pulled and have no idea what to do next or how to get to the water pump.... Please help.
Will Sick
06-26-2006 20:32:08
 Re: water pump leak farmall H in reply to Eddie123, 06-26-2006 14:18:43
If you have the radiator off you then take off the water pump drive on the front. The drive is brass and has a bold thru it to hold the drive to the shaft. The packing nut is 7/8 inch. After you take the nut off put a new packing in and tighen it fairly snug.You may get by just tightening the nut if it isn't turned all the way in. A parts book or repair manual will show these parts and is very helpful.
JTenn
06-26-2006 19:32:58
Have you tried to put grease into the water pump ?
There are two grease fittings on the pump. If you don't grease the seals they get dry and will leak. Its a quick check
Dave_Id
06-26-2006 15:47:10
You didn't need to pull the radiator to get to the pump. Remove the fan blade, and if you have room, try to add one or two packing washers. That might be all it needs, but you may have to remove all the old ones, and put new ones in.
