WD 9 Mag
OK PSU Kid
06-26-2006 14:40:12
The mag housing on my wd 9 broke, no big deal I have a box of extra mags. So last Sunday I tried to put one on and couldn't get the timing right. #1 on compresion; crank pulley on DC; bolt mag on; turn one full rev(all 4 stroks); turn towards engine till click. right thanks
Harold H
06-26-2006 15:23:01
 Re: WD 9 Mag in reply to OK PSU Kid, 06-26-2006 14:40:12
Be sure the mag is for a diesel as they turn the opposite direction from the gas mags.
Harold H
RustyFarmall
06-26-2006 14:52:34
Don't quote me on this but I think the mags for the diesels rotate in the opposite direction, so unless the mags in the box are for a diesel they won't work.
Yugrotcart
06-26-2006 17:56:33
 Re: WD 9 Mag in reply to RustyFarmall, 06-26-2006 14:52:34
Yur right, they turn in the opposite direction. If he's gettin spark, installed on the tractor, he must have the right mag.
OK PSU KID
06-26-2006 16:31:58
thanks I'll look at that. It does get fire just seems like I can't quiet get it in time.
MAGMAN
06-26-2006 18:09:42
 Re: WD 9 Mag in reply to OK PSU KID, 06-26-2006 16:31:58
A mag will fire in reverse but you will not get the spark you need or the timing right. Check the serial # on the mag you took off for a letter code at the end like H472904L or H472904D or no letter code at all like H472904_ No Letter the one you put on must be the same letter code or it will not work right . Now a D and an L are both LH trip mags but have a different timing one is 15 deg one is 35 deg and that will not work either. Also a mag that need rebuilding can be weak enough to not fire her corectly. JON
OK PSU KID
06-29-2006 06:29:12
 Re: WD 9 Mag in reply to MAGMAN, 06-26-2006 18:09:42
Hey thanks Magman. I'll check in to that. Keep up the good work.
