M water Pump
sven
06-26-2006 16:31:05
Is there a place where i can get all the bearings, seals, and packing I need to rebuild the water pump on my M as a package, or do i need to buy these part seperatly. Thanks
Haas
06-26-2006 19:26:34
 Re: M water Pump in reply to sven, 06-26-2006 16:31:05
I think there is still a rebuild package available from Case/IH. However, it costs about as much as a new aftermarket pump or a rebuilt one. Cheapest is to just take the pump down and determine what parts you need and order them separately. There is a good chance your bearings are ok and all you need are seals and packing and maybe a gasket or two.
Nebraska Kirk
06-26-2006 17:50:14
Your Case/IH dealer should have the seal, packing & bearings in stock, if not, they can order them.
arod
06-26-2006 17:22:16
whoa, forget all that work, buy a good used one and call it a day.
It will be cheaper and save alot of time.
