2 Point Hitch Cylinder Problem
alfalfa
06-26-2006 18:09:27
I have a Super C with fast hitch. The drawbar will not stay up when the tractor is idle. I ordered a rebuild kit, installed it, but it did not correct the problem. It did take care of the leak.
What's up with this?
Thanks for any advice.
alfalfa
06-27-2006 05:44:15
 Re: 2 Point Hitch Cylinder Problem in reply to alfalfa, 06-26-2006 18:09:27
Thanks, I will clean the check valve.
BillWv
06-27-2006 04:32:56
If your hydraulic cylinder is good, then the leak down is being allowed by the check valve in front of the seat box.
There isn't much to it; maybe just take it apart and clean it up. Just diagram the hose routing before you remove it.
Good luck,
Bill
Wayne Swenson
06-26-2006 20:36:45
Is the check valve in the block between the control valve and cylinder leaking down?
Jimer
06-26-2006 19:03:45
Did you rebuild the cylinder or the control valve. I believe both can cause settling.
alfalfa
06-26-2006 20:06:36
 Re: 2 Point Hitch Cylinder Problem in reply to Jimer, 06-26-2006 19:03:45
Rebuilt cylinder & put new seal in control valve.
