compression on a super m
super red
06-27-2006 09:09:59
today I bought a compression tester and checked my super m with the valves set at 17 it read 135-140 I closed them to 14 it read 130 I opened them at 20 and it read 145 to 150 on all the cylinders .so should I set them at where I get the highest reading?
RustyFarmall
06-27-2006 10:53:34
 Re: compression on a super m in reply to super red, 06-27-2006 09:09:59
Yes, set them where you get the highest reading. I have found that the .017" spec is good only for an engine that is at maximum operating temperature. If you set them at .017" at less than max temp. they will not have enough clearance when the engine IS fully warmed up. I set them at .020" cold, and have been told that maybe .025" cold would be OK.
super h
06-27-2006 15:35:39
 Re: compression on a super m in reply to RustyFarmall, 06-27-2006 10:53:34
yes I agree I use my super mta for tractor pulling and farm work so I want to have the max HP for both .
