Need Super M Carb Jet
CBice
06-27-2006 09:19:31
Can anyone tell me where to get a couple of jets for a Super M carb, the dealer says they no longer make them. The part number is #56646D,seat?
Thanks Clif
RustyFarmall
06-27-2006 10:36:52
 Re: Need Super M Carb Jet in reply to CBice, 06-27-2006 09:19:31
Are you talking about the main metering nozzle?
CBice
06-27-2006 12:49:21
 Re: Need Super M Carb Jet in reply to RustyFarmall, 06-27-2006 10:36:52
This is the jet inside the carb , you adjust it from outside the carb, togive it more fuel, I drilled it out to much and now can't adjust it , to much fuel. Thanks clif
ChadS
06-28-2006 05:47:25
 Re: Need Super M Carb Jet in reply to CBice, 06-27-2006 12:49:21
That can be fixed, by drilling and tapping the casting where the jet was, and install a jet from a Holley carb. If you drill it straight, you can still use the adjustable load screw, or you could find the jet size that works the best, and not need to use the adjustment screw at all. If you drill out another main jet in another bowl, it dont take much,,, find the drill bit that fits your stock jet, then buy a drill bit that is 5 sizes larger than the bit size that you used to measure the stock jet. You remove the metering stem, and drill out the center of the jet. Dont go to deep or you will hit the casting and ruin the bowl. With the same bit, drill out the bottom 2 holes of the metering stem. Clean out the shavings, and reassemble. Chad
RustyFarmall
06-27-2006 14:56:36
There is no need to drill out that seat. If you want more fuel, you drill out the holes in the metering nozzle. The part you need is no longer available from Case-IH or any other supplier that I am aware of.
CBice
06-29-2006 08:05:59
 Re: Need Super M Carb Jet in reply to RustyFarmall, 06-27-2006 14:56:36
Thanks for the help.
Clif
