wet sleeves on super a
amo
06-27-2006 09:29:43
A FRIEND IS REBUILDING A SUPER A AROUND 1950 THAT WAS STUCK AND HAD WET SLEEVES. HE WAS TOLD TO USE A SPECIAL LUBRICANT WHEN PUTTING IT BACK TOGETHER, THE NAPA PLACES DOES NOT KNOW WHAT HE IS TALKING ABOUT . IF ANY BODY KNOW THE NAME PLEASE LET ME KNOW AND THANKS IN ADVANCE.
K.B.-826
06-27-2006 16:32:25
 Re: wet sleeves on super a in reply to amo, 06-27-2006 09:29:43
John Deere sells a special soap for lubricating cylinder sleeve packings. Really, dish soap will work just fine. The Deere stuff comes in a large bottle, not worth buying for one engine, it only takes a few drops and you've probably already got a bottle of dish soap.
gene bender
06-27-2006 16:23:58
Just need a lube around the o-rings anything handy will work. Before putting the o-ring in the groove make sure the sleeve goes in easy. You will need to use a short cap screw and washer to hold the sleeve as when you start installing the pistons and rings and have to turn the engine over to tighten the rods the drag on the sleeve will pull it loose. Just dip the piston and new rings in new oil before installing in the new sleeve. NAPA has a good lube for the bearings when installing them. good luck
old
06-27-2006 10:07:00
Please turn off the CAP lock. I have always been told to use dish washing liquid when installing wet sleeves.
Dave Sherburne NY
06-27-2006 17:16:17
 Re: wet sleeves on super a in reply to old, 06-27-2006 10:07:00
I'm hard of hearing and need the shouting if it
bothers you turn the volume down.
BillWv
06-27-2006 10:01:26
I prefer Ivory liquid dishwashing soap, same as for changing tires.
Good luck,
Bill
scotty
06-27-2006 09:43:08
Dish washing liquid.
scotty
