engine surge
Spaceman
06-27-2006 13:38:59
I have a Farmall Super A. The engine RPM surges up and down while under moderate load. I checked the governor and it seems ok. What could cause the surging?
Dave_Id
06-27-2006 16:13:16
 Re: engine surge in reply to Spaceman, 06-27-2006 13:38:59
Check your manual as far as governor adjustment. There is a setscrew that can be adjusted on the governor that will get rid of the surge. Did it on my B. Should have the same setup.
old
06-27-2006 14:24:01
I had a tractor that was doing that at any trottle setting or any load it was a problem with the carb needing to be cleaned up/rebuilt. I rebuilt the carb and the problem went away
HAS
06-27-2006 14:20:50
Weak governor spring maybe?
