LH Thd. tie rod end (for 1206) part number ???
Way Up Here
06-27-2006 16:42:51
Does anyone out there have an original (or aftermarket with mfg) part number for a left hand thread tie rod end for an IH 1206? Thanks for the help !!!
Randy in NE
06-28-2006 04:20:32
 Re: LH Thd. tie rod end (for 1206) part number ??? in reply to Way Up Here, 06-27-2006 16:42:51
The part number for the END ASSY, tie rod, LH thd is 384005R91. The entire tie rod assembly is ROD ASSY, adj tie 385814R91.
K.B.-826
06-27-2006 16:52:21
Don't have the part number on hand, but it's a very common part. If you've got a Case-IH dealer nearby, they'll probably have one on the shelf. If you've got a Deere dealer nearby, they should be able to order you one through A&I, their aftermarket parts company. Try NAPA, they can probably get you one.
