Fasthitch won't hold position
PaulW_NJ
06-27-2006 19:53:48
The Fasthitch on the 340 utility I purchased last year won"t hold position. If I move the lever (quadrant?) to raise the hitch slightly and then don"t move the lever any further, the hitch will continue by itself to its top position. If I move the lever the opposite way just a little, the hitch will continue to drop to it"s lowest position. I can"t keep the hitch in any intermediate position.
It was suggested that the check valve spring might be broken, but I disassembled it today and found it is a one way check valve, and that the spring looked fine as well as the rest of the insides (valve, seat, ball, etc.). I plan to replace the Orings in it but don"t know if that alone could be the problem.
Has anyone encountered this problem, and what did you find the problem to be? Thanks alot.
Colorado Curt
06-28-2006 07:37:56
 Re: Fasthitch won't hold position in reply to PaulW_NJ, 06-27-2006 19:53:48
I was searching through the archives on this subject the other day. I have a 460 Ute with the same problem. Mine has the cable linkage and I have a used replacement that has different linkage. My plan was just to swap out the valve, but it looks like I will need to do some swapping of the internals instead. I have read that getting the timing correct on the spider gears is difficult. Check out the archives.
Hugh MacKay
06-28-2006 02:57:09
Paul: First check the external draft control linkage going from control valve to the hitch cylinder. Some of those linkages were enclosed cable and others had a system of rods and pivots. If that is unhooked or broken anywhere, the hitch will do as you describe.
If the linkage is intact then your problem must be internal in the control valve. The control valve while it looks like other remote control valves, internally it has a set of spider gears much like a differential. On one side of that valve there is a lever connected to linkage I mentioned in first paragraph. On the other side the control valve lever. Those spider gears connect the two sides and if damaged or broken will have the same effect as external linkage unhooked.
If those spider gears are broken, I'm not sure you can still by new ones. My 560 had those go in mid 1970s and they were quite pricy back then. I replaced my valve with a complete regular valve from a 300. Of course I lost the draft control feature. If you don't mind loosing the draft control any remote control valve from a 300, 400, 330, 350, 450, 340, 460 or 560 will fit and operate hitch.
