axle bearing failure on C ??
SDE
06-28-2006 03:42:49
I had been pulling the back half of an eight foot tandem disc set at full angle of cut, for over a half an hour. Switched to a single five foot section of a drag. About the third round it suddenly started making a dry rumbling, metal on metal, type of sound from below, in the rear end housing. I stopped, and backed up a foot and it still made the noise.
I had used the brakes for turning but they had not made any noise or been grabbing at all. Could one of them be the source of the noise?
If it is a bearing, do I jack it up and rotate each axle to find which it is? Do I dare tow it 100 yards to get it into the barn? Is it likely to be something else?
The fluid level was checked last month and had needed about a quart.
sde
06-28-2006 16:55:25
 embarassing to admit in reply to SDE, 06-28-2006 03:42:49
This happened at nine last night. Today I look at it and find that the left brake pedal had stuck against the battery box. Released it and she works good. Thank you for your time.SDE
gene bender
06-28-2006 10:49:49
 Re: axle bearing failure on C ?? in reply to SDE, 06-28-2006 03:42:49
I would drive it slow to the shed then jack up one wheel and check them one side then the other. Mite want to remove the brake cover and check that also cause that could be the culprit. If a bearing fell apart the wheel would have some up and down play.chances are the brake has somethig foreign inside.
