Transmission Help
Joel Cassell
06-28-2006 07:17:48
Hello,
Anyone help with a 424 International stuck in reverse gear? The shifter goes into 2-3, and high gear, at which time the transmission is in two gears and bogs the motor. The tractor is in reverse when the shift lever is in neutral.
Is there any way I can diagnose this without pulling the top of the transmission off? I would really appriciate help here.
CNKS
06-28-2006 09:43:05
 Re: Transmission Help in reply to Joel Cassell, 06-28-2006 07:17:48
I'm not that familiar with the 424, but on some tractors you can pull the shifter and align the rails. Nothing to lose by doing that. If that fails then remove the cover. See if there is a pin you can remove at the base of the shifter, it may be covered with caps.
Joel Cassell
06-28-2006 10:19:55
 Re: Transmission Help in reply to CNKS, 06-28-2006 09:43:05
Thank you. I will try that.
