Wiring switch on 300 RC
Levi K
06-28-2006 19:51:04
third party image
I have a new bright, dim, off switch, which is the shiny thing in there, what is the function of each of those prongs? I know that Allen tried to help me but he didn't know I have a RC.
Levi K
06-29-2006 18:05:54
 Re: Wiring switch on 300 RC in reply to Levi K, 06-28-2006 19:51:04
Which on is the power terminal?
scotc
06-29-2006 04:19:59
I think I see four terminals. One will be power in, one will be for the work lights and another may be for a tail light and I believe it would only come on with the brights. Hook the power lead to one of the posts and touch the wire to the lights to one post at a time, then cycle your switch, until you find a combination of posts that do what you want them too.
scotc
06-29-2006 04:35:40
 found allen's info in reply to scotc, 06-29-2006 04:19:59
The posts should be the same, as that switch should be generic across the different models. What he didn't know about was the red taillight in the rear work light housing. Hooking it up like he said to should get you working.
