H Coolant leak
IndianaRed
06-28-2006 20:08:24
third party image
As I wait for my new rod bearings, I've noticed small droplets of coolant at the front bottom of the block. The only coolant left is in the block. Is this the kiss of death?
Steven@ND
06-28-2006 20:34:42
 Re: H Coolant leak in reply to IndianaRed, 06-28-2006 20:08:24
Are you sure it's coming from inside the block?
Be very sure it is not running down the front of the block from the water pump area before you jump to conclusions.
Personally, for the amount of money that gets poured into an (quality) overhaul I wouldn't risk a potentially cracked block.
IndianaRed
06-28-2006 20:38:03
 Re: H Coolant leak in reply to Steven@ND, 06-28-2006 20:34:42
Ya, the front is dry, pump and housing are dry. Kept hoping is was just some that splashed up when I emptied rad., but it's definately from inside. Can't tell where. Bummin.
Tom Windsor
06-28-2006 20:27:31
The folks on this forum have recently taught me that this is a dry sleeve block so new o rings are not going to cure the problem.
If you have droplets of antifreeze down there you definitely have a crack in the water jacket and it does not need to get into the oil.
Could be kiss of death depending on the severity.
I rebuilt a G Allis Chalmers this spring. It had a crack in the block. I welded the crack and it still had pin holes that weeped. Did not know what to do so I got some stuff from NAPA and put it in the radiator--it seems as if it were somekind of fiberglass or something. The directions were to pour it in the water and run it for 30 minutes. I ran it for an Hour and it quit leaking. I have been running it without incident since then. So, if you have a hairline crack in the water jacket...it "might" be worthwhile to try this..you have nothing to loose, do it, run it, then change the oil...see what happens...if it fails...then you are into a diffrent block.
Tw
