Farmall 140 transmission gears same as A and B?
RBH
06-30-2006 11:54:02
I have to replace a couple of gears with broken teeth on my 140 and probably a bearing. I understand that the Super A trans is the same as the 140. Will the gears out of a A or B trans be the same as the 140. Thanks.
Hugh MacKay
06-30-2006 17:49:53
 Re: Farmall 140 transmission gears same as A and B in reply to RBH, 06-30-2006 11:54:02
RBH: I wouldn't go back any further than 52 Super A. Although the gears look the same, and have same ratios, the later tractors have gears with a different hardening process. I forget the particulars on this and exact serial number when the change occured. Ask CNKS he may know.
CNKS
06-30-2006 19:53:05
 Re: Farmall 140 transmission gears same as A and B in reply to Hugh MacKay, 06-30-2006 17:49:53
I don't know. I thought by the time the 140 arrived, that maybe IH no longer used the straight cut gears? My C transmission has the same gears as the Super A -- I just looked up the part numbers. My C transmission is quiet. The A,B,Super A transmissions are know for their noise, including mine -- wonder why? Only difference would be the final drives, unless I'm missing something.
never had a problem
06-30-2006 15:07:58
I just put togehter a trans with gears out of a couple different trannies. They are the same gears according to the books.
banjo
06-30-2006 12:34:08
from what i can tell the gears are the same in a b tranny as the super a.
so if they are the same in the 140 as the super a then you should be good to go.
I'm not an expert so someone else should come along shortly with the skinny.
