valve clearance adjust.ment
george2125
06-30-2006 15:26:34
I have a farmall c and want to adjust the valves.This will be my first time adjusting valves. What is the correct way of doing this . The shop book its not clear on how to do this. Thanks george
El Toro
07-01-2006 04:12:14
 Re: valve clearance adjust.ment in reply to george2125, 06-30-2006 15:26:34
After the engine is heated up you pull the valve cover and adjust them with the engine at an idle.
Set them at .014" with a feeler gauge. Hal
Bob
07-01-2006 00:40:30
Here's the OFFICIAL way...
Link
old
06-30-2006 16:06:05
The best way to do it or at least I think it is. Warm up the engine by running it about 30 minutes, you can have the hood off so you can get the valve cover off faster. Then when its still warm turn the engine over by hand and when a valve is pushed down adjust the valve that is closed and keep do each one that way. That way you know for sure that the valve you adjust is as closed as it can get and the adjust is correct. I.E. when an exhaust valve is open you adjust the intake and so on
the tractor vet
06-30-2006 16:40:23
 Re: valve clearance adjust.ment in reply to old, 06-30-2006 16:06:05
On the old 4 lungers i do it by firing order 1342 as i cheet i pull the plugs out then i can see TDC on each .
george 2125
06-30-2006 16:34:10
Old , this might be a stupid question , but how do you know the valve is closed. thanks george
old
06-30-2006 18:55:46
 Re: valve clearance adjust.ment in reply to george 2125, 06-30-2006 16:34:10
Well if you look at the rocker arms one will be down/pushing the valve down and the other one will be up and should have some slack/play if you push down on and pull up on it, the valve side of it. When you take the vlave cover off and then turn it over by hand just watch the rocker arms and you wil understand better what I'm talking about. You almost have to be blind in one eye and not be able to see out of the other one to miss it. LOL
Yugrotcart
06-30-2006 18:44:27
The valve next to it, same cylinder will be opening, pushed down.
