Farmall C weight
SLH from MO
06-30-2006 19:17:14
Can anyone tell me how much a C Farmall weighs Without fluid and with fluid in the tires. THANKS
Pete76NY
06-30-2006 22:04:44
 Re: Farmall C weight in reply to SLH from MO, 06-30-2006 19:17:14
Depnds on if it has quick hitch or not, ours with no juice in the tires but with the quick hitch cannot make it into the #3000 class even without a driver, without the hitch, Hyd pump and rocker arms it squeaks in under 3 grand.
Louis Kocon Jr
06-30-2006 19:34:58
International Harvester Tractor Data Book lists the weight of a Farmall C as, "2780 pounds without fuel or water." No other data listed. Hope this helps.
