I Did It!!
IndianaRed
06-30-2006 19:30:41
third party image
I can't believe it. Bought my first tractor from here, an H. Was rough with a bad bang in the engine. Opened up the bottom, spun rod bearing. One piston was cracked in half. Antifreeze in sludge/oil. Smoked bad. Got a a lot of good advice from people here. Most said to pull the crank, take that and the head to a machine shop. But me being me and always trying to do it for less, didn't do that. Instead, I trusted in the stories I'd read in here about guys finding an old Farmall that had sat for years, (like mine), changed the oil, filter, fresh gas and a prayer and she runs straight off. Well, I had to do more to mine, (one piston, 1 rod, 2 sets of rings, and 3 sets of undersized rod bearings. And I have never been inside an engine before. Watched grandad and my uncles on the farm, but never anything like this. So easy to get to everything to fix. I kept saying to myself as I was tearing down, "I can put this back, I can put this back too". Didn't have to set valves, adjust timing or anything. Got it all back together tonight, hit start, and she fired up immediately. Runs smooth and beautiful! I know I may have to re-repair some things I should've maybe done this time, but I really didn't have the money, and I just wanted to see what would happen with these repairs before I got into more. Called my grandparents, parents, uncle, girlfriend, sister, and best friend just so they could here it run. This is the greatest day of my life.
Tom Windsor
06-30-2006 20:54:35
 Re: I Did It!!--yes you did! in reply to IndianaRed, 06-30-2006 19:30:41
Happy for you. This engine is a slow-low compression and very forgiving...economical...a man after my own heart---You did good..With the decals you are ready to go.
Tom Windsor
Tom Windsor
06-30-2006 20:54:33
Tom Windsor
IndianaRed
07-01-2006 04:22:15
 Re: I Did It!!--yes you did! in reply to Tom Windsor, 06-30-2006 20:54:33
Thanks Tom,
In between waiting for parts I've been priming and sanding grill and hood. Very time consuming but yes, ready for the decals soon! Just another beautiful piece of iron saved from the scrapyard. Appreciated your input along the way tom, thanks.
Bri
Nebraska Cowman
06-30-2006 19:38:45
 Re: I Did It!! in reply to IndianaRed, 06-30-2006 19:30:41
Hey, that's pretty nice. The H is sure one of my all-time favs. Just got in from hauling water to the pumpkins with one of mine.
