OLD - spark plugs II
GeorgeH
07-01-2006 11:01:27
Thanks for info on A15/D21. One more thing, someone before me put in the D21 plugs and they also have 2 washers on three of them. Any idea why someone would do that?
John T
07-01-2006 18:53:31
 Re: OLD - spark plugs II in reply to GeorgeH, 07-01-2006 11:01:27
George, Adding an extra plug washer is one "Old Farmers Trick" to make the plug run hotter. Ive seen it done when the plugs are fouling but its sort of a band aid fix like when they add an extra lil air gap in the plug wire to the plug to make a partly fouled plug go ahead n fire.
John T
old
07-01-2006 12:30:51
2 things come to mind on that. One is they could get the plugs to stop letting a little compression by pass out the ring which is a sort of a seal for the plug. Or they wanted to pull the hotter plug back and of the picton just a little to keep from burning a hole in it. You never know for sure unless you can talk to who ever did that and then sometimes they don't even know why they did it.
RustyFarmall
07-01-2006 12:56:27
 Re: OLD - spark plugs II in reply to old, 07-01-2006 12:30:51
OR, the washer from the old plug was left in the hole, and a new plug with new washer was installed. It does happen.
old
07-01-2006 13:40:11
 Re: OLD - spark plugs II in reply to RustyFarmall, 07-01-2006 12:56:27
Good one I didn't think of that one
