How to check oil level in m trans
Harry Howard
07-01-2006 17:12:30
I found the drain plug, also found the fill plug, where did they hide the dip stick/pet cock,or whatever you can tell if its full? Before the manual policestart in, YT hasd no manual listed ,TSC has no M manual in the local store. This is a 51 M. Thanks HH
Nebraska Kirk
07-02-2006 13:51:11
 Re: How to check oil level in m trans in reply to Harry Howard, 07-01-2006 17:12:30
There is a plug on the left side, near the front of the transmission case. With the tractor on the level, the oil level should be up to that check plug.
Don L C
07-01-2006 19:07:50
Try Binder Books for that mauual...503 684-2024
jossette
07-01-2006 18:22:20
I would let it sit on an uphill grade for a week and then loosen the drain plug to get the water out and then fill the trans until it comes out the plug on the side.
amo
07-01-2006 18:19:32
SEE POST UNDER TRACTOR TALK TITLED PARTS BOOK AND MANUALS. A MANUAL WILL SURELY HELP
Hermit
07-01-2006 17:48:12
If you click on "Tractor Manuals" on the left side of the page then search "International/Farmall/MD" and "M" you'll find all kinds of manuals for an M.
