1586 AIR BLOWER
JIM MA
07-01-2006 18:42:10
THE BLOWER SWITCH TURNS THE COMPRESSOR ON BUT BLOWER DOESNT. THE TEMPERATURE SWITCH IS GOOD MAYBE JUST BLOWER BAD. ANY THOUGHTS LET ME KNOW
JJK
07-02-2006 06:40:18
 Re: 1586 AIR BLOWER in reply to JIM MA, 07-01-2006 18:42:10
Make sure that when you pull the squirrle cages off that you lay them aside so they go back on the new motor the right way the first time. Its easy to get turned around with those things.
jim ma
07-02-2006 05:49:48
thanks gary all works except blower. guess i got to pullit out thanks jim
IaGary
07-02-2006 04:46:39
On those 86 series tractors the fan,radio,wipers and ditital tact if so equiped are all on the same relay.
Sooo if the radio and wipers work, the fan is either bad or you have a bad connection to the fan.
If the radio doesn't work either, it could be the relay or the key switch.
When you turn on the key you can hear the relay snap in down in the fuse pannel if it is good.
Theres few things for you to check to start finding your problem.
Gary
