330u Electrical Problem
Tweeter
07-03-2006 09:21:47
I posted the other day about my battery decharging. Today I tested it by taking the ground wire off battery and putting a test light inbetween the wire and ground post on battery and it does light up. What is my next step to solve the problem? Starter? Solenoid? Key Switch?
John T
07-03-2006 10:47:34
 Re: 330u Electrical Problem in reply to Tweeter, 07-03-2006 09:21:47
Tweeter, if theres a battery current discharge path heres one way to find it. If you remove the hot ungrounded batery cable from its post and place the wire and alligator clamp end of a test light to it (leave battery cable unattached) and touch the probe tip end of the test lamp to a frame ground it lights up i.e. it finds a current return path (like a SHORT) correct?????
Sooooo ooo how I do it is take the probe end and touch n prod n probe it to different terminal and wiring locations TO SEE WHERE IT LIGHTS UP I.E. THE SHORT.
NOTE The tests n probes need to be made on the upstream BAT input terminals on like switches cuz if its probed to the downstream side of switches where the loads are it would naturally light up since it finds a ground through the loads. WHAT YOURE LOOKING FOR is short return paths that SHOULD NOT be present. The input BAT terminals on switches should not offer a current return path when OFF unless the switch is bad or a wire is shorted etc.
Other methods are to remove wires one at a time and see if n when the shorting path stops or if a wire is removed and momentarily scratched/contacted up againt a terminal that has a current return shorting path, a small spark will happen i.e. if theres no current flow available there wouldnt be any sparks when you attach a hot wire to it. DO NOT be making sparks at the batery especially its top.
Common places to find a short are frayed worn wires or switches or mis wired gennys or VR's or alternators etc.
Best wishes n God Bless
John T
RustyFarmall
07-03-2006 09:46:08
Has the tractor been converted to a 12 volt alternator system? If so, and the wiring is not correct, your battery will discharge when the engine is not running. Check out the link, there are a couple of diagrams there that show the proper way.
Illinois Boy
07-03-2006 09:30:54
I'd start at the key / ignition switch - test to a good ground. Then work your way around the other components following the circuit (current flow)
If the switch is working right - there should be no voltage present from that to ground, unless the key is on!!
You can disconnect wires and test in series or leave connected and test in parallel. I prefer to disc and test in series, but that's just me...
