H fouls plugs
farmallboy
07-03-2006 11:27:56
Why is my H fouling plugs.
farmallboy
07-03-2006 14:45:54
 Re: H fouls plugs in reply to farmallboy, 07-03-2006 11:27:56
Yes my tractor is smoking, black smoke is what comes out most of the time.
Janicholson
07-03-2006 15:46:12
 Re: H fouls plugs in reply to farmallboy, 07-03-2006 14:45:54
While it is running, with the throttle open wide, brakes locked, in neutral, adjust the screw on the bottom front of the carb in (CW) the smoke will get less and less. Keep turning (might be more than one turn) till the engine starts to stumble a little. Then screw it out till it runs nice again then 1/4 turn more. Try it under load and in operating from idle to full throttle. If it runs well, it is fixed. If not adjust so that it is not hesitating and not making smoke. If it will not quit making smoke when screwed in, the carb needs (at least) a float adjustment. Good luck,
JimN
RustyFarmall
07-03-2006 18:01:08
 Re: H fouls plugs in reply to Janicholson, 07-03-2006 15:46:12
Actually, the load adjustment screw for the H is located underneath the carb, and points down and to the rear.
Janicholson
07-04-2006 16:28:45
 Re: H fouls plugs in reply to RustyFarmall, 07-03-2006 18:01:08
That depends entirely on the model of carb, The idea ia valuable though. JimN
CNKS
07-04-2006 16:54:57
 Re: H fouls plugs in reply to Janicholson, 07-04-2006 16:28:45
There was only one carb design for the H, he might confuse the bottom front with the top front, which is the idle adjustment, and get nowhere. M, Super H, Super M, etc had a completely different carb with the main screw as you described.
Charlie M
07-03-2006 13:10:44
Could be lots of reasons - too much gas, burning oil, bad points, wrong type of spark plugs. Is your tractor smoking and if so, what color smoke. Need to get more information to help you on this one.
