smta hitch
Hayfarmer
07-03-2006 12:49:13
I pull a baler with my SMTA with a swinging drawbar. I block it in the cneter position but due to the movement of the baler it tends to loosten up, has also worn a spot on the drawbar where the roller works. I believe the front attachment of the drawbar is worn oblong. Would it be better to move the swinging drawbar to the side and attach a hitch plate to the drawbar frame instead? What do others do with Ms etc?
Hugh MacKay
07-04-2006 02:39:39
 Re: smta hitch in reply to Hayfarmer, 07-03-2006 12:49:13
Hayfarmer: Having spent many years with this same drawbar on H, 300 and 560, I know all to well the problem you are having, no one likes a loose drawbar for pto work. I'm not sure I agree with the advice your getting. If over the years you have used bolts to keep swinging drawbar in center, the two holes you are going to mount the triangle plate on will be worn, thus the plate will be impossible to keep tight as well.
Here was my solution, use the swinging drawbar, fabricate a U bolt that will fit tightly over roller and down through the two holes you now use. Then fabricate a cap for bottom that has set in blocks to hold the swinging drawbar firm, from side to side motion. Make those blocks deep enough so hitch weight stays on the roller. I used these during periods when doing a lot of pto work. The down side is they do slow you down if you want to swing the drawbar, but so does the triangle plate.
Don L C
07-03-2006 16:27:04
I.H. made several styles of 5/8 or 3/4" triangler shaped plates.....we used one on our 50-T bailer even though it had its oun engine....the bailer would work back and fourth when the plunger made a stroke.....they were olso used ,bolting the 27-V mower drawbar to the M drawbar (2 required)...
RustyFarmall
07-03-2006 14:22:54
The optional, triangular shaped hitch plate was intended for just that, PTO work.
Aces
07-03-2006 13:04:40
Hayfarmer Yes
Hayfarmer
07-03-2006 18:10:46
 Re: smta hitch in reply to Aces, 07-03-2006 13:04:40
Thanks for the replies. Had a bolt that holds the roller break and drop the baler hitch to the ground, jammed up the pto but luckyly didn't break anything. Started thinking about the sort of triangular shaped plates I had seen for this.
Nat 2
07-04-2006 05:29:52
 Re: smta hitch in reply to Hayfarmer, 07-03-2006 18:10:46
One problem with that, though...
The axle housings were not designed to be the primary pull points on the tractor. It'll be okay if you're just tugging around a little baler and dropping bales on the ground, but if you're hauling loaded wagons up and down hills, you're likely to rip the axles right off the tractor!
Best to fix the oblong hole in the drawbar up front... Someone with a welder can do that easily.
If you go the plate route, make sure you get the distance right from the end of the PTO to the center of the drawbar hole. Otherwise, you end up with knocking knuckles.
Dr.EVIL
07-05-2006 11:13:09
 Re: smta hitch in reply to Nat 2, 07-04-2006 05:29:52
NAT - You're not correct about pulling from the rear axles. IHC made a LOT of different high draft attachments that pulled from the axles... Plows were pulled from a twisted clevis attached to the U-shaped drawbar, not the swinging drawbar.
