Cast center front hubs
Chad Enyeart
07-04-2006 08:05:08
I have a set of heavy cast front center hubs that is on a wide front end for a Super C tractor. The casting number on the hub is 9350D. Can anyone tell me what these are supposed to be for. I have never seen a set of these before and have a few more questions about them. Thanks for any help you can provide.
CNKS
07-04-2006 09:11:56
 Re: Cast center front hubs in reply to Chad Enyeart, 07-04-2006 08:05:08
Extremely common item, sold on new IH tractors until the late 50's.
Nebraska Cowman
07-04-2006 08:51:49
They are lited in the parts book for A, SuperA, C, and Super C
Chad Enyeart
07-05-2006 04:23:35
 Re: Cast center front hubs in reply to Nebraska Cowman, 07-04-2006 08:51:49
The other front hubs that I have my Super C is a lighter casting with a flange cast into it to mount the rims to. The casting number of these hubs are 6787-DE. Does either on of these hubs use an actual wheel seal or do they use a felt packing? I have not had these apart nor do I have a manual. Thnaks for any help that you can provide.
CNKS
07-05-2006 18:35:59
 Re: Cast center front hubs in reply to Chad Enyeart, 07-05-2006 04:23:35
They have both -- if you disassemble it, keep the parts in order and see your CIH dealer. If you don't have one, call Carter and Gruenewald at 866-327-6255. Either will have what you need. Both wheels use the same parts, far as I know.
