Super C governor
trw
07-04-2006 16:13:37
My governor doesn't seem to be working on my Super C. The throttle linkage works going into the governor, I mean it moves the arm that goes into it, but it will not move the arm that goes to the carb linkage. I can't even move the carb linkage by hand to make the engine speed up. Everything seemed to be working very smoothly when we put the governor in. All the linkage is hooked up correct. Anybody have ideas on what I need to check to get this fixed? Thanks a bunch!!
gene bender
07-04-2006 19:18:40
 Re: Super C governor in reply to trw, 07-04-2006 16:13:37
you mite have put the spring in wrong as the hooks open end need to be facing the housing.
504-1
07-04-2006 18:56:10
trw, Sounds like you broke the spring in the governor
