Farmall B rear light
DJL
07-04-2006 21:08:04
Still working on the B restoration. Next week we'll be ready to sandblast and prime the cast. I've got the two original headlights restored and ready to put back on, but have a question with the rear one. I don't remember it ever having a rear light, and I don't see a mounting bracket for it, but i'm sure there was one at one time. What type of bracket goes on the rear, where's it bolt to? Did the B's have the same teardrop 6V light on the rear as was used on the front or should it have the one with the additional red lens light mounted on top of the teardrop?
Thanks
DJL
Dave H (MI)
07-05-2006 08:10:05
 Re: Farmall B rear light in reply to DJL, 07-04-2006 21:08:04
Do a search on ebay for that bracket for a week and eventually you will find a good picture ( I found one under ebay auction 260003420248 ). Be patient if you are bidding on these, however. When I bought mine I saw auctions where this single bracket was selling for as much as $36.
About the seventh one I bid on went for less than $10 and I was happy to get it so cheap. Ebay is crazy sometimes when the right (wrong) people get to bidding.
gene bender
07-05-2006 02:54:21
Rear lite fastened to a bracket that was bolted to the left seat support where the three holes are. The fixture is the same as the two on the front. The stem is shorter than the two for the front. The bar the lite mounts on is shorter. I have the parts.
