What size are the square drive drain plugs?
CharleyFarmall
07-05-2006 04:28:00
1/2" drive is too loose it seems which means it is larger but what size? It's not like there is a square drive drain plug wrench out there, and the local shop doesn't have square stock in all different sizes to sell. What do you guys do?
the tractor vet
07-05-2006 08:34:55
 Re: What size are the square drive drain plugs? in reply to CharleyFarmall, 07-05-2006 04:28:00
Mac tools offer square drain plug sockets as i have both the square and hex males . They are made to fit the plugs alot better then any breaker bar or ratchet now with out going out to the truck and give ya all the sizes they start at around 1/4 up to like 3/4 maybe and inch . Now like all special tools they do not come cheap. But they do not round out drain plugs .
Greg-N-CA
07-05-2006 06:16:46
I took a piece of square steel larger that the plug and ground the end to fit. I then bent the steel to make a handle to turn the plug. It's a simple, but effective tool for the job.
CRUSADER
07-05-2006 05:52:10
You may want to try using some 8-point sockets.
Nat 2
07-05-2006 06:04:50
 Re: What size are the square drive drain plugs? in reply to CRUSADER, 07-05-2006 05:52:10
How would that help? He's talking about the square-drive drain plugs, the ones that have the square socket sunk into them. An 8-point socket is only useful for pipe plugs.
MAGMAN
07-05-2006 04:32:59
I believe its 3/4' If you get a 1/2 to 3/4 adapter that will work or a 3/4" socket set. You can get an apdapter at alot of the parts stores or sears. JON
