noise in the clutch housing
george2125
07-05-2006 07:46:55
I have a farmall c. Rebuilt the engine, got it back together, and started it up.It makes a clunking noise from the clutch housing.Now, when i assembled the clutch i did not use an alignment tool. Could that be the problem?the clutch is not align? thanks george
old
07-05-2006 09:23:35
 Re: noise in the clutch housing in reply to george2125, 07-05-2006 07:46:55
Forgot to say one other thing you may have done was put the disc in backwards and that will also cause you that problem
old
07-05-2006 09:22:37
Andy sounds like hes on the right track. Flywheel loose preassure plate loose or you broke something putting it back togeather. I have never been able to get and engine back into any thing with out useing a clutch aliment tool of some sort since they have to be right on the money to go back togeather. So much as a 1/16 of and inch off and parts will brake
Andy Martin
07-05-2006 08:04:43
The clutch alignemnt tool just helps you get it together. Unless you broke something forcing the tractor together, I suspect you left the flywheel bolts loose. Pull the starter and see if you can wiggle the flywheel.
