W-30 boiled over last night !
Pete LaBelle
07-05-2006 09:57:56
Hey all -
Had my W-30 on a Baker fan for about an hour last night running pretty full throttle, but a little under rated govenor speed. After about 50 minutes of this, coolant was running out the overflow, and when the radiator cover was removed, about a half gallon of fluid spilled over the tractor. Level was previously checked at about 1-1/2" below the top. Air temp was about 70F. Was this too much load for the old girl, or are other problems looming on the horizion?
Tractor was purchsed last year old & unrestored & running great, but engine was never opened up.
Seeking your wisdom ..... .
Pete
Charlie M
07-05-2006 17:38:27
 Re: W-30 boiled over last night ! in reply to Pete LaBelle, 07-05-2006 09:57:56
There is a thermostat in them - maybe rusted shut. I had to take the thermostat out of mine as it works on a bellows and mine had rusted off. Haven't been able to find a replacement so I run it without one. Can you see water flowing into the top of the radiator? How's the fins on the radiator - clean or plugged up.
