rear axel farmall a
MIKE CASE
07-05-2006 19:28:58
would like to know if there is a secret to pulling the axel out of my A i have the bearing cap off both ends and the pan off the main gear and the bolt off the inside bearing cap.....any help
gene bender
07-06-2006 03:45:55
 Re: rear axel farmall a in reply to MIKE CASE, 07-05-2006 19:28:58
If you have the bearing cap on the inside off and the nut off the axle should pull out. But if the bearing is shot mite run into some problems. Use a piece of brass and a few good raps should pop out. I have never had any problems after doing what you have done.
MIKE CASE
07-06-2006 03:54:15
 Re: rear axel farmall a in reply to gene bender, 07-06-2006 03:45:55
Thanks I will give it a try and let you know how i come out..... so long
banjo
07-05-2006 20:39:09
have to take the final drive off and remove the brake drum also. Or are you just wanting to remove the bull gear?
MIKE CASE
07-06-2006 03:01:00
 Re: rear axel farmall a in reply to banjo, 07-05-2006 20:39:09
iI WANT TO REPLACE THE BEARINGS IN THE LOWER UNIT
