fast hitch question
Jefd
07-06-2006 09:54:42
I would like to add the 3rd arm to a fast hitch on my 350. What do I need to do? Is there a simple bracket to bolt on, or will it be a major production? Thanks!
jimmyjoe from mn
07-06-2006 16:55:33
 Re: fast hitch question in reply to Jefd, 07-06-2006 09:54:42
third party image
This one is on my 560D, I had to modify it to get
the hole low on this one.
jimmyjoe from mn
07-06-2006 16:49:14
third party image
This is the one I made for my smta. I had to get the hole for the top link as low as I could so it
would work right.
Wardner
07-06-2006 13:29:21
Goto the Worksaver site and look at their exploded drawings for the 350-450 conversions. You should be able to fabricate the stuff quickly. Type www and dot com around worksaver.
wilson holloway
07-06-2006 10:33:35
Get flat bar 1/2 in.by 2in.& cut 2 piece\s about 4in.long.Round at 1 end to fit rock shaft.Cut or drill 3/4in. hole in other end. Lift fast hitch as high as it will go.weld 2piece\s to rock shaft.Makes nice top link. Thanks Will Have any questions 863 452 0308
Allan In NE
07-06-2006 10:51:49
 Re: fast hitch question in reply to wilson holloway, 07-06-2006 10:33:35
Whoops!
Wasn't payin' attention to the 350 part. :>)
Please disregard my blabberin'.
Allan
Allan In NE
07-06-2006 10:08:02
To convert to a 3-point? Yes, bolt on the factory bracket, which should have came along with the center link and the lower link adaptors.
Be aware tho, they don't work so very good and you're not gonna like it. :>(
Allan
