1951 M Electrical problem
Jerry Deimerly
07-06-2006 11:36:37
I bought a 1951 M in January. It had been starting fine, but this morning it will barely crank over. It’s still a 6 volt system, but had a new oversized Interstate battery when I got it. The metal case had been cut at some point to accommodate the larger battery. I was looking at the diagram, “Electrical Schematic for Farmall H/M Stock 6 volt w/cutout by wrm Aug 03” and noticed on my tractor the negative battery terminal is grounded to the tractor and the positive cable runs to the starter switch and then on to the starter. Now I’m wondering if that is causing a charging problem. But, if the cables are reversed at the battery, would the starter still rotate properly? (I figured it would run backward). Would that damage the generator or just keep it from charging? Can I simply reverse the cables at the battery so I have a positive ground and negative to the starter switch as the diagram shows or is there more I need to do to avoid possible damage (or is it already done?) If so what are the likely problem areas. Thanks in advance for all your help.
John T
07-06-2006 12:50:05
 Re: 1951 M Electrical problem in reply to Jerry Deimerly, 07-06-2006 11:36:37
Jerry, take care in battery polarity swapping, its okay provided you correctly re polarize the genny before you start her, but if you dont it could do a number on the Voltage Regulator. Of course, if it has an ammeter and you change polarity its leads need reversed or she will read bass ackwards and if its a battery powered coil ignition system the coil should be wired to match the battery polarity and could also need its leads reversed. Its only those permanent field magnet motors that would run bass ackwards if polarity were reversed, yours will still turn the same way regardless as Bob M pointed out.
Heres my Standard Troublesghooting Procedure for Non Charging, it and Bob's flow chart may be wayyyyy y more then you need but ought to help you diagnose the problem like if its a genny or VR issue.
On an M at 6 volts I also would want the biggest heaviest rated battery possible PLUS use 00 Gauge Battery n Starter n Ground cables to reduce voltage drop.
TROUBLESHOOTING CHARGING SYSTEMS
ARE YOU SURE THE AMMETER IS WIRED CORRECT AND WORKS????? If you turn the lights or ignition on (if coil ignition not a mag) when she’s not running, the ammeter should swing over to the - discharge direction, does yours??? Are BOTH the ammeter terminals reading hot battery voltage?? They MUST !!!!! ! There’s but one wire on the ammeters Supply (from battery/starter) terminal while its other Load terminal wires to the BAT terminal on a Cutout relay or VR PLUS wires to feed loads like lights or ignition, unless where a 4 terminal VR is used where lights n ignition are fed from the LOAD terminal on the VR.
To Polarize the Generator, first temporarily dead ground the Gens Field post to case/frame, then momentarily flash jump a wire from the Cutout Relay or VR's "BAT" terminal over to its GEN (or ARM) terminal and you ought to get a small spark. Same things accomplished by momentarily flash jumping a hot wire (BAT terminal on Cutout Relay or VR or starter post etc) direct to the Gens ARM post to get the spark.
TROUBLESHOOTING A CHARGING PROBLEM IN CLASS A DELCO TYPE SYSTEMS
1) For a good working Gen to get to and charge the battery, it has to have a path usually from the Gens ARM post,,,,, ,,,,to and through the Cutout Relay (between its GEN and BAT terminals, regardless if on a VR or Relay),,,,, ,,,up to the Load (NOT to battery) side of the Ammeter,,,,, ,,,to and through the Ammeter,,,,, ,,,,from BAT side of Ammeter to ungrounded battery terminal, often via the starter lug post. Is yours wired that way or equivalent ??? The ammeter should read hot battery voltage on BOTH terminals, does yours??? Even if an ammeter were stuck (but still continuous) as RPM increases the battery voltage should rise from 12.6 to near 14 volts and/or the lights glow brighter (half that on 6 volt systems). Have you tried that in case the ammeter isn’t working right?????
2) If the above is so, the BAT terminal on the VR or Cutout Relay MUST ALWAYS READ HOT BATTERY VOLTAGE. Does yours??? If not, the Gen cant get to and charge the battery.
3) The Gen to VR (if it has one) wiring is as follows:
BAT on VR to ammeters load (NOT battery) side
ARM (or GEN) on VR to Gens Armature post.
FLD on VR to Gens Field post.
(L) Load (if you have a 4 wire VR) up to BAT supply input terminal on switch to feed loads like lights and ignition.
WIRING ON CUTOUT RELAYS: They wire BAT side to ammeters Load terminal,,,,, GEN side to gens Armature post. On cutout relay systems, the Gens Field post is wired to the light switch where it gets a dead ground for high charge or a resistive ground for low charge. Therefore, there must be a good connection from the Gens Field post up to the switch PLUS the switch is good and it’s well grounded !!!!! !!
4. THE GEN AND VR OR CUTOUT RELAY MUST BE WELL GROUNDED AND THE BELT GOOD N TIGHT. If any doubt, run a ground wire from the grounded battery post or clean solid frame member direct to the Gen and see what happens????? ????? ????? ????? ????
NOW, if the Gen and VR are grounded,,,,,all is wired correct,,,,, ,,BAT terminal on VR or Cutout Relay is HOT,,,,, ,,Belt is tight,,,,, ,,,Ammeter is good n continuous n works but she wont charge, have you had the batteries tested lately????? Is there electrolyte above all the plates and no cells have a gray or milky appearance????? A bad battery may not accept a charge you know!!!!! !! If the battery checks okay, proceed below to see if its a Gen or VR problem (AFTER you have insured the wiring per the above)
TO DETERMINE IF ITS A GEN OR VR OR CUTOUT RELAY PROBLEM
5. a) VOLTAGE REGULATOR SYSTEM: With the tractor running, temporarily ground the Gens Field post to case. If she charges then but NOT otherwise, the VR may be bad, or a wires missing from VR's Field post to the Field terminal on the VR, or the VR isn’t well grounded.
b) IF IT’S A CUTOUT RELAY SYSTEM and she charges only if you dead ground the Field but NOT otherwise, its either a bad switch or the switch isn’t well grounded or else the wires bad or open from the Gens Field post up to the switch. INSURE THAT GOOD SWITCH GROUND AND WIRING
6. If she still don’t charge, leave the Field grounded and jump a wire across from the VR or Cutout Relays BAT terminal over to its GEN terminal (jump by passes the cutout relay) and see if she charges. If then but not otherwise, a VR's cutout relay isn’t working correct (maybe points burned/carboned) or a Cutout Relays NOT working or not wired correct.
7. With the 2 steps above, you have basically by passed the VR or Cutout relays functions, so if she still don’t charge, you're left with a bad battery or wiring or the Gen itself.
8. MOTOR TEST. You can Motor test the Gen. If its grounded and you remove the belt and apply hot battery voltage direct to its ARM Post and have the Field Post dead grounded to frame, it should motor n run well (Armature n Brushes and Commutator likely okay). Then, if you next remove the Fields ground and it speeds up some, the Fields probably good. If it passes both those tests, it should charge, and if not, it may be a wiring or battery or grounding problem. The hot battery voltage may be taken off the VR's BAT terminal or the starter post or the battery itself for this test.
9. Typical Gen problems may be the brushes are worn down or the hold down spring assemblies are stuck/corroded/dirty and arent pushing the brushes tight down against the commutator. Check those things out. Worse may be bad fields or armature etc. Air and WD 40 etc can clean and free them, the hold downs must be free n snap and hold the brushes DOWN TIGHT and they cant be worn down too low.
SUMMARY: Check the wiring,,,,,the grounds,,,,, insure BAT on VR or Relay is hot,,,,, ,check battery (maybe load tested and Specific Gravity checked),,,,, ,,,good tight belt,,,,, ,insure ammeter is continuous (BOTH sides HOT),,,,, see if battery voltage rises above 12.6 (half that for 6 volt system) and/or light glow brighter,,,,, ,,,do the Field and cutout relay VR by pass checks,,,,, ,,insure the Gens brushes arent worn down and the hold down springs are free n clean and push the brushes down tight,,,,, ,,,,,check the connections,,,,, ,,,try the Gen Motor Test to see if its good.
You may just have a bad battery or bad ground or connection if the Gen and VR or relay are okay. Good Luck n God Bless, let us all know.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks over on the Mother Deere pages instead of over here on the "dark side" lol
Bob M
07-06-2006 12:06:02
Jerry – First off, the M starter is ground polarity insensitive – it rotates the correct direction on both positive and negative ground.
As for the rest of the M electrical system, for the most part it also is ground polarity insensitive. As long as the generator is polarized after the battery has been installed and the ammeter is wired correctly, the tractor will run fine and the battery will charge on either polarity. (Incidentally however your M did come from the factory connected positive ground....)
From your description it sounds like your battery is running down – i.e. it’s not being charged when the engine is runs. Suggest working through the generator troubleshooting flow chart (punch below) to isolate the problem.
However if you find the generator is charging and the battery is charged up, slow cranking means a bad connection (look at the battery, starter switch or frame ground), a bad starter switch or a tired starter.
