300U hyd question.
old
07-06-2006 19:04:23
A friend of mine is useing my NH 45,46,47 sickle mower but it has a single acting cylinder and its not work on his 300U Is there a way to use it or do I just brake down and put the double acting cylinder on it?? I worked good, I know its green but any how it worked well on my Oliver 77 but I think the hyd system on the farmals is differant then one the Olivers. Thanks for your insite
FromJB2
07-06-2006 19:58:16
 Re: 300U hyd question. in reply to old, 07-06-2006 19:04:23
Hi Old, on the 300U that we had, each hydraulic control valve had a selector control in it. It was on the front end of the valve and it had an indicator pin that pionted to "S" for single or "D" for dual acting remote. The selector was changed by using a 1/2" wrench and turning it to piont at either "S" or "D".
Hope this helps
JB2
jeffcat
07-06-2006 20:55:36
 Re: 300U hyd question. in reply to FromJB2, 07-06-2006 19:58:16
Yes this is how my dads 300 is. The tractor has three valves on it and the "rear" valve needed to switch for a disk harrow. Jeffcat
CNKS
07-06-2006 19:37:03
Not sure of the 300, but the 460 remotes each have a knob (my 460 manual calls them "valve pins") that would allow single or double acting cylinders to be used.
old
07-06-2006 20:27:17
 Re: 300U hyd question. in reply to CNKS, 07-06-2006 19:37:03
I know his 450 has that and tomorrow I'll have to look and see if thats the problem. Sure wish farmalls where like the Olivers and didn't care which one you used but they aren't so I'll have to adapte
