1066 wont go
Bill Ramsey
07-08-2006 09:31:20
I was baling this morning with 1066. Parked it in gear came back started tractor raised bucket let out on the clutch and nothing. I have shifted thru all gears high and low T/A and nothing. It feels like its going in gear but nothing . What could be wrong?
THE TRACTOR VET
07-08-2006 16:59:51
 Re: 1066 wont go in reply to Bill Ramsey, 07-08-2006 09:31:20
As the old sayen goes HUSTON WE GOT A PROBLEM . Do you have PTO ???? IS the hyd oil level up to snuff did pices fall out the bottom when ya looked ??? . Is your Dump valve Tel Tale lite working , is it on?????
430LPG
07-08-2006 12:36:01
Could have broken the center out of the clutch plate, The hyd. drive off of the pressure plate so they would work. Take the inspection plate off under the clutch and see if there is pieces of springs and rivets.
