Farmall H carb and tires
H fanatic
07-08-2006 15:00:51
hello once again,
I have a 1946 farmall H and I was wondering how to adjust the carb? It runs to rich! Also how do you adjust the idle speed. I want to get it to idle slower. It idles faster than all the other H's I've seen. Also my H has 12.4x38 rear tires could I fit 11.2x38 tires on the same rims? Thanks for all the advice you guys gave me on my previous post! Nick
todd in michigan
07-08-2006 19:12:38
 Re: Farmall H carb and tires in reply to H fanatic, 07-08-2006 15:00:51
You need a good set of manuals. you can start here and download the parts manual here free. THe idle jet small screw with a spring towards the top and the main jet is the big screw at the bottom with the spring. A good starting point of reference for your carb is "The idle mixture screw (idle jet)is set at 1 1/2 turns out. The load mixture screw (main jet) is set at 3 turns out." so tighten your jets down slowly and count how many turns to get to the bottom and then see how far off the reference point you are. 3 turns out is a starting point, fine tune from there.
H fanatic
07-08-2006 20:14:12
 Re: Farmall H carb and tires in reply to todd in michigan, 07-08-2006 19:12:38
Todd in michigan,
Where can I find the Parts manual to download? Or does any one else know?
todd in michigan
07-09-2006 06:07:08
 Re: Farmall H carb and tires in reply to H fanatic, 07-08-2006 20:14:12
check your email
Skyhawk Greg
07-09-2006 20:05:25
 Re: Farmall H carb and tires in reply to todd in michigan, 07-09-2006 06:07:08
Hi Todd, I am interested in where the parts manual can be downloaded as well. Thank you. Greg
todd in michigan
07-10-2006 06:50:16
 Re: Farmall H carb and tires in reply to Skyhawk Greg, 07-09-2006 20:05:25
cleancomputes.com/Cub/
half way down the page.
Skyhawk Greg
07-17-2006 10:10:33
 Re: Farmall H carb and tires in reply to todd in michigan, 07-10-2006 06:50:16
Thank you Todd! Took till now to get it all downloaded. Greg
