Farmall H - How do you tell?
mc2
07-08-2006 19:21:43
I have inhereted a Farmall H 1943. It has hydraulics. Does that make it a Super H? It has a screw-on gas cap. Is this correct? The inlet for the gas to go into the tank is a pipe about 1 inch tall with threads on it. It looks factory but every gas caqp I have seen do not use pipe threads. I need an expert on H's!! Thanks
Farmall Ed
07-09-2006 06:00:13
 Re: Farmall H - How do you tell? in reply to mc2, 07-08-2006 19:21:43
The serial number might be helpful for idenity. Ed
schertz70
07-08-2006 21:04:59
I beleive the motor is slightly bigger in a "super h".
CNKS
07-08-2006 19:41:02
Super H was not produced until 1953. Cap/inlet is not factory.
mc2
07-08-2006 20:39:08
 Re: Farmall H - How do you tell? in reply to CNKS, 07-08-2006 19:41:02
So the hydraulics doesn't make a tractor a "super"? What did? and you say the gas cap is not factory. The inlet is perfectly installed. Had to be factory. No one can weld that smoothly. Could it be from another letter tractor? Unfortunately my father-in-law has passed away or I would ask since this is a one owner tractor.
CNKS
07-09-2006 07:27:28
 Re: Farmall H - How do you tell? in reply to mc2, 07-08-2006 20:39:08
All H's and M's had hydraulics as an option. The "Stage 2" Super H and Super M had live hydraulics (I was told recently that the non-live belly pump was also an option on the Stage 2 Super M). The Supers had other features such as different locations for the controls, disk brakes, and the battery under the seat on the Stage 2's as well as the larger engines. Again, your fuel inlet was not on a factory tractor. As far as welding, I have taken parts to professional welders and the weld came back nearly invisible. So it can be done.
Nebraska Cowman
07-09-2006 03:13:39
The Super had a change in horsepower, gearing, and disk brakes. I'd like to see a picture of the fuel tank inlet.
mc2
07-09-2006 18:12:52
 Re: Farmall H - How do you tell? in reply to Nebraska Cowman, 07-09-2006 03:13:39
From all the replies, for which I sincerely appreciate, my H is not a super H. No disk brakes, no live hydraulics--the clutch has to be out to operate them. Glad to solve that question. The gas cap still remains a mystery. My wife says it has been that way for over 50 years that she knows of. She drove that tractor as a child to help her father bale hay. Yes I will post a picture and maybe that will help explain. I really appreciate everyones help.
old
07-08-2006 21:02:05
One thing that is need to make it a super is the year. Another is haveing live hyds not hyds that only work when the cluthc pedal is out. Also a number of other thing but not sure what they are
