Transmission noise
mc2
07-08-2006 20:30:49
I have a 1943 Farmall H which emits a noise or clanking in gthe tranny when going down an incline in every gear except 1st. No noise in first gear but shift to 2nd and let out the clutch and let the tranny hold the speed down and it will clank. changed the gear oil. No help. What can it be??
Theman
07-10-2006 07:59:33
 Re: Transmission noise in reply to mc2, 07-08-2006 20:30:49
I think you have a bearing out. The 1st - reverse gears are at the back end of the countershaft and since you don't hear the noise in low gear, it will be one of the front transmission bearings of which there are 4: 1) The pilot bearing as mentioned in an earlier post, 2&3)The two driver (input) shaft bearings, or 4)The countershaft front bearing. Fortunately, all of these bearings can be changed without removing the top deck or splitting the tractor. Just drop the Liftall pump and remove the drive shaft. Drain the transmission oil next. It will only be necessary to remove the front plug which means you probably won't need more than a 5-gal. bucket.
Since it is the easiest to get to, check the countershaft bearing first. Remove the slotted Liftall driver (right-hand thread) and take the oil seal housing off (3 screws). Thread the driver back on the shaft and wiggle and listen to it to see if that is the source of the slop. If you hear the familiar clunk, you've found your problem. This bearing has an external snap ring on the outer race which doesn't need to be removed. Instead, use it to help you work the bearing out. There is a snap ring at the other end of the shaft so you don't have to worry about pulling the shaft out of place.
To get to the pilot bearing, which is your next suspect, remove the input driver shaft housing. You don't have to remove the front yoke to do this. Just take out the 6 or so cap screws on the housing and pull it out straight forward. Looking inside the transmission, the pilot bearing is on the end of the shaft. It is a roller-and-cage type bearing. The shaft and the inside of the constant-mesh gear you just removed serve as the bearing races. Inspect all surfaces and make sure all the bearing rollers are there. It is easily removed when you take the bolt out of the end of the shaft. This bearing is uncommon and unless you have a very knowledgeable local source, go to Case/IH. It will help if you don't go on an empty stomach.
The other two bearings are in the housing you just took out. Check for excessive slop. This can cause a lot of growling noises - even in neutral since it always drives the countershaft. If you have to take it apart and the yoke is stuck tight, put a spacer or short socket on the end of the shaft and use the long clutch shaft with a couple of 3/8" bolts to "pull" the yoke off.
If there is any sign of leakage, replace the seals. Gaskets are available from Case/IH. If they are the 63 year old originals, it is recommended.
mc2
07-10-2006 11:05:40
 Re: Transmission noise in reply to Theman, 07-10-2006 07:59:33
Thanks so much. I needed the very detailed directions on this. At first chance, I will follow your suggestions and see what I find. I appreciate you guys for all the information to us that lack it.
Janicholson
07-09-2006 08:20:16
A gear that is chipped on the side away from the driving force will make noise when loaded backwards. I would live with it unless it is getting worse and worse. You can "see" into the trans to a limited degree by taking off the belt pulley (or cover if it is not equipped). There is a chance that you might see the problem if it is on the main shaft teeth. JimN
JJK
07-08-2006 23:12:11
I worked on an M a while back that did somthing like that. It was somthing with the pinion shaft. Seemed like it was a retaining bolt in the end of the shaft came out pushed the pinion through the snap ring and further into the ring gear. I remember that I couldn't fix the threads in the shaft because it was to hard for the tap so we had to have a machinist do it. I know I had to tear the tranny down a ways to fix it but that is about all I can recall. Probobly just what you wanted to read, huh!
mc2
07-09-2006 18:18:05
 Re: Transmission noise in reply to JJK, 07-08-2006 23:12:11
Well, since it no longer is under the strain of farming, I might have to live with it. The old girl is retired and living a less active life.
