Need Electricl Schematic-6volt to 12 volt 140 trac
James Lee
07-10-2006 08:12:57
Could anyone send me a wiring schematic to convert a 140 Farmall tractor from 6 volts to 12volts. We are using a GM alternator. Thank you.
Gary In Mozarks
07-10-2006 11:04:16
 Re: Need Electricl Schematic-6volt to 12 volt 140 in reply to James Lee, 07-10-2006 08:12:57
The picture above is a Delco 12SI Make sure you have a three wire alternater if you use the picture above. They also make an internally excited one wire alternater that is in common use.(internally excited) they look exaclty the same. (you can convert a one wire to a three wire and visa versa by installing the appropriate voltage regulator in it).
Bob
07-10-2006 08:22:10
Change the coil to a true 12-Volt coil, or add a ballast resistor ahead of the coil you have.
Connect the coil's (+) terminal to the ignition switch (or resistor, if used), and the coil's (-) terminal to the distributor.
Connect the alternator like the photo below.
Third Party Image
You can use a #194 lamp as an "idiot light" in place of the diode.
Change any lights to 12-Volts.
Hobo,NC
07-10-2006 20:16:19
 Re: Need Electricl Schematic-6volt to 12 volt 140 in reply to Bob, 07-10-2006 08:22:10
Bob I am surprised you kin come over here and post yer 3 wire set up and not offend enny one or find sumone who needs a hug, seriously guess you found the trouble makers over were I hang out most of the time. I have found it best to not answer their post or replies it realy pizz’izz’em of more. Theirs more than you read think about it and I am not sure what they are up to, Sure hope I out live’em or they loose their job. Keep up the good werk I really like yer style.
Bob
07-11-2006 22:43:24
 Re: Need Electricl Schematic-6volt to 12 volt 140 in reply to Hobo,NC, 07-10-2006 20:16:19
Hobo, check your email!
James Lee
07-11-2006 12:05:33
Thank you Bob. Got it going with your help.
