Farmall H Bearings
Jeff Bauer
07-11-2006 12:06:40
I"m going back through my 47 H and restoring it the right way. I"m fixing all the little leaks from front to back. My brake jackshaft seals were leaking so I got it apart to replace them and I found that the brake jackshaft bearings are bad so I need to replace them. Cheapest I"ve found is $75 each at NAPA. The bearing # is L-245 anyone know where I can get cheaper bearings or is this about the right price.
El Toro
07-11-2006 18:41:32
 Re: Farmall H Bearings in reply to Jeff Bauer, 07-11-2006 12:06:40
Try this web site to see if they can cross-reference your bearing number. Their phone number is 215-513-4601. Hal
http://www.ptplace.com
justin w
07-11-2006 15:38:36
did you check with Case IH? in the past, they have always kicked everyone"s prices on these bearings.
Aces
07-11-2006 13:27:13
Jeff Bauer I would think you could do better at a bearing and seal store, or maybe McMaster Carr on the web.
