Spark Plug question
Harley
07-12-2006 06:22:52
I know, this has been beat to death but I have Champion 16 plugs in my M and putting up hay they carbon up and about once a day I have to take them out and scrape the carbon off them to keep them running. Then ok till the next time. Is there a better or hotter plug to use. Thanks, Harley
ryan from WI
07-12-2006 19:17:11
 Re: Spark Plug question in reply to Harley, 07-12-2006 06:22:52
I use Autolites 386 work the best.
John T
07-12-2006 07:17:52
Harley, sounds like a lil hotter plug may help your situation. Ive seen guys even add an extra plug washer on some plugs which makes em run hotter. Theres Autolites that fit n work that are hotter then the 3116, but its advantage is its a NON resistor so you might give it a try. Good wire core wires and good adjusted points may help plus dont run the carb any richer then necessary to avoid excess black smoke from over rich running which blackens n fouls the plugs. Make sure the air cleaner n inlet piping are clean n free and the choke opens full n stays open and the floats not set too high.
Dont hesitate to give her a good general igntion tune up (cap rotor wires points n condensor) cuz it can help and its not all that expensive, then start out with the hotter plug n with the carb adjusted if needed n see what happens
Let us know
Best wishes n God Bless
John T
Andy Martin
07-12-2006 06:33:10
I'd try turning the main jet in 1/4 turn at a time and see if you can lean it out a little and still get good power. That may clean up the plugs and save you a little gas to boot.
Red Dave
07-12-2006 06:31:48
I've switched to Autolite 3116, with good results so far.
This is like asking what the best oil is: you'll get a lot of differing opinions.
migraine
07-12-2006 07:40:35
 Re: Spark Plug question in reply to Red Dave, 07-12-2006 06:31:48
I went to D-21 plugs in several of the old 4 cyl I.H. tractors and has really helped the fouling, especially the H with one weak cylinder. Also using them in 2 of the 560 6 cyl with same good results. Migraine
Allan In NE
07-12-2006 08:43:50
 Re: Spark Plug question in reply to migraine, 07-12-2006 07:40:35
Me too.
Couldn't believe the difference the D-21 plugs made.
Allan
Andy Martin
07-12-2006 08:48:18
 Re: Spark Plug question in reply to Allan In NE, 07-12-2006 08:43:50
I've been using only D21 plugs for years.
Bob M
07-12-2006 09:19:26
 Re: Spark Plug question in reply to Andy Martin, 07-12-2006 08:48:18
Same here! Switching to D21 plugs 7 or 8 years ago completely eliminated my plug fouling problems.
Bartt
07-12-2006 14:35:17
 Re: Spark Plug question in reply to Bob M, 07-12-2006 09:19:26
Is a D-21 plug an Autolite plug? Thanks
Bob M
07-12-2006 19:33:53
 Re: Spark Plug question in reply to Bartt, 07-12-2006 14:35:17
Bartt - The D21 is a Champion plug.
Bart
07-13-2006 01:27:30
 Re: Spark Plug question in reply to Bob M, 07-12-2006 19:33:53
Thanks Bob A lot of rain in New York? About 40 0r 50 days straight here in Northern Vt. Thanks again.
Bob M
07-13-2006 07:49:15
 Re: Spark Plug question in reply to Bart, 07-13-2006 01:27:30
Lotsa rain in western NY indeed! 4.9" in my gage over the past two days.
Harley
07-12-2006 10:01:27
Thanks guys, gonna get-er-done. Harley
