Add on hydraulics
Chad Enyeart
07-12-2006 08:43:56
I have a super C with the factory cultivator lift system on it. I purchased one of those blocks that you put between the steel lines to and from the pump and the hydraulic system. Here is the questions that I have for you. Should I use an open center or closed center hydraulic valve for the loader that I am putting on? Should the flow be in series or what. I might be over thinking this but any help that you can provide would be greatly appreciated.
Bob
07-12-2006 09:46:43
 Re: Add on hydraulics in reply to Chad Enyeart, 07-12-2006 08:43:56
Use an open-center valve, in series. A closed-center valve is for use only on a system designed as closed-center, and if you put it on your tractor, it would completely block hydraulic flow from the pump, and the pump or gear drive train would likely break.
Closed-center system pumps go "out of stroke" when you oil flow is needed.
