biger pistons how
Baxter
07-12-2006 17:41:22
I rebuliding my M's engine putting new rings sleves pistons etc and how do you hone out the cylender and is it easy to take sleves out and back in with a slev puller. Thanks
in-a-bind
07-13-2006 00:29:31
 Re: biger pistons how in reply to Baxter, 07-12-2006 17:41:22
Sleeves are not too hard to install in a M engine.
I pulled a set using a OTC sleeve puller, and reinstalled the new sleeves after letting them sit in the frezzer for 24 hours.
Make sure that your wife don't see them in HER FREZZER, or you may hear some stuff.
Just use a hone with a medium grit stone to lightly scratch the surface of the new sleeves.
Don't forget to retorque the head bolts after a few hours of running time.
When I rebuilt mine I used the 4 1/8 inch firecrater type pop up pistons, and they sure made a world of difference between them and the standard flat top pistons that I removed from it.
