Super A Right Angle PTO
City-Boy McCoy
07-13-2006 04:51:18
I wish to install a right angle pto on my super A. Does anyone know what years and/or models of this unit from regular A's, 100, 130 and 140 will simply bolt on my 1953 super A? I have ben told there are fitment problems between some years. Another person told me they are all the same. Thanks. mike
Jim Becker
07-13-2006 05:46:36
 Re: Super A Right Angle PTO in reply to City-Boy McCoy, 07-13-2006 04:51:18
Serial break for the change on the A was 66671. As far as I know, anything after that through 140 will be essentially the same. Beware that entire PTOs may have been moved between tractors so look for pulley drive housing 9090D.
You can't just slap the attachemnt on. Bevel gear mesh is set with shims. It may be easiest to just change an entire pulley and PTO attachment from another tractor. If you get an entire unit from an A, you need to reuse your current PTO shifter (the hollow tube that slides on the drive shaft).
City-Boy McCoy
07-13-2006 06:04:16
 Re: Super A Right Angle PTO in reply to Jim Becker, 07-13-2006 05:46:36
Jim:
This is great information and just what I needed to know. Thank you so much. mike
