Farmall 340 Hydraulic Pump Problems
Tobaccoman
07-13-2006 17:23:58
This tractor has the externally mounted hydraulic pump on it. After the previous owner replaced the pump and it was working for me, the tractor sat unused for several months. Upon restarting, I had no hydraulics. Took out and cleaned the filter screens etc. Still nothing! Plenty of fluid in reservoir of course. So, has anyone else had this problem and if so, how do I remedy it? Or any suggestions from anyone. I certainly would appreciate your experiences and your help. Thanks.
Tobaccoman
07-14-2006 18:34:38
 Re: Farmall 340 Hydraulic Pump Problems in reply to Tobaccoman, 07-13-2006 17:23:58
Thank you guys for taking the time to help me out. I will certainly try your suggestions.
Tobaccoman
PUTTER
07-14-2006 07:04:11
I have the same problem with my 340, I just crack the line where the big hose connects to the steel line at a high idle she should pick up the prime. GOOD LUCK PUTTER
MN Mike
07-14-2006 05:37:15
Last winter I wasn't paying attention to my 340 and lost all the trans-hydraulic fluid. When I remedied the problem and filled the reservoir I had the same problem you are describing. Found a set screw on top of the pump I took out with an allen wrench. Poured fluid in to prime the pump and everything started working again. If this works for you, start checking lines for an air leak.
